HELP!! 06 speedo inop, shift points increased alot
Old May 26, 2007 | 08:30 PM
blie's Avatar
Default HELP!! 06 speedo inop, shift points increased alot
i have a 06 monte with a 3500. my speedo went out along with the odometer. the tach works. the car shifts with a pause at high rpm's. any idea's on what can be wrong. my warrenty is up so i hope it is not to bad
Old May 27, 2007 | 09:13 AM
Monte_04's Avatar
Default RE: 06 speedo inop, shift points increased alot
My tac went the speed o went too on my '04and i dont think anything else works i have to change the whole cluster. you can check some fuse's i think.
Old May 27, 2007 | 02:26 PM
blie's Avatar
I checked all fuses.
Old May 27, 2007 | 02:39 PM
Monte_04's Avatar
Then it just might be that its gone bad, thats what mine has done.
Old May 27, 2007 | 11:55 PM
Mrrench's Avatar
base warranty is 3 years or 36,000 miles
Most likely the speedo problem will be covered under it
I would think the problem will be with the main ecm.
Does the DIC work?
Old May 29, 2007 | 08:40 AM
blie's Avatar
Does the DIC work?
I'm guessing you ment compass? No it doesn't.
Old May 29, 2007 | 09:03 AM
04MonteLS's Avatar
Yeah, my car, same thing. But it shifts and drives fine otherwise.
Old May 29, 2007 | 10:32 AM
Mrrench's Avatar
DIC
is the information center where the odmeter is displayed at
Old May 29, 2007 | 12:34 PM
blie's Avatar
Yea, that works, well it's functional. Alot of the features will display with zero's like mpg etc due to no speedometer i guess.
Old May 29, 2007 | 01:12 PM
Mrrench's Avatar
Speed o meter runs off a sensor on the transmission
All the speed o / odmeter is a device that shows the output of the transmission
Speed sensor tells the ecm what the car is doing, in turn the ecm tells the driver thru the speed o
not as sample as that but as close as I can explain it
You might want to take the car to AutoZone and hook a reader to it
these might be a couple of codes that they might pull from it
[*]P0500 - Vehicle Speed Sensor (VSS) Circuit[*]P0501 - Vehicle Speed Sensor Range/Performance[*]P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input[*]P0503 - Vehicle Speed Sensor (VSS) Circuit Intermittent
The change in shift points is because the ecm is not getting a vehicle speed reading so the computer shifting the car in default mode
