synthet oil bad for real high miliage?
ok i thought i read or heard somwhere that synthetic oil is bad for a car that has rather high miliage becuase the oil is thiner...it's oil change time on my daily driver that has 197xxx miles on it
and i have run nothing but castrol gtx highmiliage in it since we've bought it and am thinking of going synthetic... is there any truth to this?that its bad? or should i be all good?
I think you should be fine! Just use the same grade of oil in a synthetic form so if your using 10w-40 Castrol, then stick with 10w-40 synthetic.
I switched my truck to synthetic at 205,000ish miles, and now i'm at 230,000 with no problems at all.
I am a 100% believer in synthetics!
well reading article after article searching a few dif forums...basicly if it leaks....it'll leak worse so as far as i know it doesnt leak....i think ill take the plung and switch over...worst case
well switched it over yeaterday... man it runs smooth... noticed a 100 to 200 rpm drop at cruising speeds saweet
MonteCarlo579
07-06-2014 11:46 AM
TMoney
04-09-2014 09:32 AM
Red Nightmare
10-18-2013 07:08 PM
wann
09-10-2013 11:19 AM
InTheBlue
07-08-2009 03:38 PM
