synthet oil bad for real high miliage?
Old Aug 3, 2009 | 09:53 AM
Budsjlm's Avatar
Default synthet oil bad for real high miliage?
ok i thought i read or heard somwhere that synthetic oil is bad for a car that has rather high miliage becuase the oil is thiner...it's oil change time on my daily driver that has 197xxx miles on it
Old Aug 3, 2009 | 09:56 AM
Budsjlm's Avatar
and i have run nothing but castrol gtx highmiliage in it since we've bought it and am thinking of going synthetic... is there any truth to this?that its bad? or should i be all good?
Old Aug 3, 2009 | 12:06 PM
RocknSS04's Avatar
Can't say for sure, but with over 600,000 miles on synthetics now, I sure am a believer.
Old Aug 3, 2009 | 02:48 PM
MAMONTE's Avatar
I think you should be fine! Just use the same grade of oil in a synthetic form so if your using 10w-40 Castrol, then stick with 10w-40 synthetic.
I switched my truck to synthetic at 205,000ish miles, and now i'm at 230,000 with no problems at all.
I am a 100% believer in synthetics!
Old Aug 3, 2009 | 05:33 PM
Budsjlm's Avatar
well reading article after article searching a few dif forums...basicly if it leaks....it'll leak worse so as far as i know it doesnt leak....i think ill take the plung and switch over...worst case
Old Aug 3, 2009 | 05:34 PM
Budsjlm's Avatar
senereo i it leaks and i switch back
Old Aug 6, 2009 | 12:00 PM
Budsjlm's Avatar
well switched it over yeaterday... man it runs smooth... noticed a 100 to 200 rpm drop at cruising speeds saweet
Old Aug 7, 2009 | 02:25 AM
sonin66's Avatar
if your car doesnt leak,you shouldnt have a prob switching. you will know if you have a oil leak
MonteCarlo579
Jul 6, 2014 11:46 AM
TMoney
Apr 9, 2014 09:32 AM
Red Nightmare
Oct 18, 2013 07:08 PM
wann
Sep 10, 2013 11:19 AM
InTheBlue
Jul 8, 2009 03:38 PM
