Suspicious noise
Old Jul 18, 2011 | 09:39 AM
Chevy13's Avatar
Default Suspicious noise
Just wondering is anybody had any ideas as to what is happening with my car. About a month ago I notice a noise coming from what I think is under my car (drivetrain, wheels). Its hard to explain the noise be its kinda like a wheel bearing. You hear the sound for one second then off for one second and so forth. So its not one constant sound, its on and off. And, I only hear it on a paved road with the windows up between the speeds of 100Km/h - 130Km/h. I drive to work on a 4 lane Hwy so these are the speeds I'm mostly driving at.
Now my tires are getting near bald, not quite but close. I might have 2months left with them. But that wouldn't explain why the noise is only apparent between 100 - 130. And I thought a bad wheel bearing was a constant noise. When I hear the noise I do feel it in my feet, barely but I do.
Over the month since I noticed this the problem hasn't gotten much worse maybe just a little. The smoother the pavement the more noticeable the noise. I was hoping when I first noticed this that it would just go away but its obvious its not and its starting to drive me crazy as I'm thinking it could be something major. I only have 30,000 Km's on this car and its never been winter driven. Otherwise the car drives great.
Any ideas are appreciated, thx.
Old Jul 18, 2011 | 09:56 AM
Do you have the original Brakes still on your Monte ?
I would inspect your brakes...Sometimes the disc brakes can make a noise & then go away...
Can you tell `if it's coming from the front or back ?
Do you only hear it at high speed ? Low Speeds or all speeds. ? Noise can be difficult to locate...
I hope our expert tech member's can post some suggestions.
This is the only one I have at present...Good Luck & please let us know what it was ? When & `if you find
p.s. You do have a SuperSuper Beautiful
Monte Carlo 4-Sure : )
Old Jul 18, 2011 | 10:42 AM
Mike 00LS's Avatar
Check your wheel bearings, your bushings, and your front stabilizer bar.
Chevy13's Avatar
Thx Space,
Yes original brakes, I don't suspect I should be touching those for a while though the car is 5 years old its low mileage (under 19,000 miles). If its anything down there my guess is its the calipers touching?
Can't tell if its the front of back. I think the back but not 100% sure. Only hear it between speeds 100km/h to 130km/h which I find very strange.
Old Jul 18, 2011 | 10:45 AM
Chevy13's Avatar
ok, I'll check those. What am I looking for with the stabilizer bar? And is it possible for any of this to be failing with under 19K miles on the car ?
Old Jul 18, 2011 | 08:16 PM
HEMI_DAD's Avatar
My son has a noise that just started. Seems to be coming from left front but not from brakes. How he noticed anything with the stereo & pipes!
Old Jul 18, 2011 | 08:38 PM
Justin Knight's Avatar
The noise comes and goes at speed or is constant?
Noise when cornering slightly, changes when you lean the car left/right?
Your description needs elaboration. If it comes and goes going straight it could be your a/c compressor.
Old Jul 18, 2011 | 08:43 PM
xxtheshockerxx's Avatar
RED DEVIL
Chevy13....i like your rims
Old Jul 18, 2011 | 09:54 PM
Mike 00LS's Avatar
If it's cracked - the factory ones are hollow and I hit some rough road once and broke it about an inch before the bushings and it would make a sound...it's hard to explain the sound...but it would make a noise as I drove because the two pieces of metal would rub.
Old Jul 19, 2011 | 08:50 AM
Chevy13's Avatar
I only hear the noise between the speeds 100km/h to 130km/h. Under 100km/h I don't hear it. And its constant between those speeds. And when I say constant I mean you hear the noise for 1 second then off for 1 second and so forth. I don't notice any difference when turning left or right but at that speed I'm not really turning either way.
zoe08
Aug 25, 2015 11:50 PM
Ca$$e
Jan 27, 2006 03:48 PM
ralphtrent
Sep 21, 2005 03:00 PM
kmabru
Sep 1, 2005 12:50 AM
ag3nt0r4ng3
Jul 25, 2005 10:56 PM
