Radiator Replacement
Old Jul 18, 2011 | 10:25 PM
Curtis24682007's Avatar
Default Radiator Replacement
I have a 2001 monte carlo ss and I just wanted to know if you can use a radiator that does not have a temperature sensor as a replacement? I have seen the radiator in the 2004 model at a junk yard and wonder will if it will work in my car. It does not have sensor were my car's radiator does. Will my car function properly without this sensor being hooked up? Any help would be helpful.
Old Jul 19, 2011 | 11:08 AM
Any ideas?
Old Jul 19, 2011 | 11:45 AM
Budsjlm's Avatar
i would say no
it will work but i don't know if it has just one or 2 sensors one for ecm and guage or just one for both
but if it is connected into the ecm in any way your computer will just see that the car is running extreemly cold( like start up) and won't adjust such things as fuel, timming to the temp your engine is running ie running rich/lean posibly causing KR
Old Jul 19, 2011 | 12:13 PM
Sparky-88's Avatar
Not sure if your '01 is different from my '02 SS (3.8L) but...
My radiator has only a coolant level sensor. The coolant temp sensor screws into the lower intake manifold I think (it's somewhere down there on the driver's side). If yours is like this, it should work. With the coolant level sensor disconnected, you should not receive any error code / idiot light.
However if your radiator really does have the coolant temp sensor, then I'd say you need to replace with a like unit for reasons already pointed out.
Old Jul 19, 2011 | 03:06 PM
Thanks for the input guys.
killerBee
Jul 1, 2018 02:14 PM
99MonteZ34
May 20, 2010 03:04 PM
redbug2
Oct 2, 2009 08:08 AM
wizz
Dec 27, 2007 06:22 PM
montess_24fan
Jul 6, 2007 01:42 AM
