Starting Trouble
Old Jan 4, 2007 | 01:24 PM
01pacecaredition's Avatar
Default Starting Trouble
I am new to the fourm
We have a 2001 pace car edition the problem first started with the traction control light and abs light coming on and off and now has progressed to this problem and I am at a lost. Sometimes you can get in and turn the key and hear all the elctronics come on line and the car will start but more that 60% of the time now and seems to be getting worse you put the Key in turn it do not hear any of the elctronics coming online turn the key and get NOTHING no starter noise no clicking as it would be a dead battery just nothing . All in side lights radio and headlight all come on but WILL NOT start. any one can tell me anything about this.
Mike
Old Jan 4, 2007 | 01:38 PM
benhillzone3's Avatar
Default RE: Starting Trouble
maybe you should check all your fuses to make sure none are blown or lose
Old Jan 4, 2007 | 01:40 PM
wiz kidd's Avatar
i would take it and have codes checked...sounds like more than one thing wrong with the car, and if its electrical you dont want to just start changing random parts that 'could' be the problem. sounds like something electrical like a sensor or something, and i would have the battery tested, it may not be fully gone, but it might be gone enough to cause this
Old Jan 4, 2007 | 01:43 PM
we had the battery tested at autozone they told us it was good
Old Jan 4, 2007 | 01:44 PM
see if you could go to autozone and have thhem check you codes?
Old Jan 4, 2007 | 04:21 PM
01BlkSS's Avatar
If you hold the key in the start position when it doesn't start, will it start if you hold it for a few seconds? After my traction control light/abs came on I had/have the same problem. I can turn it to start but nothing happens and if I leave it there it will start in a couple of seconds. Doesn't happen all the time. I figured out it's the igntion swtich and there is a TSB out for it. It doesn't bother me though, so I'm just going to ignore it.
Old Jan 4, 2007 | 04:45 PM
01Blkss can you tell me where to find that TSB at because I will take it in
thanks
Old Jan 4, 2007 | 05:51 PM
01BlkSS's Avatar
Here is the link where I found all the TSB's Clicky
It's about half way down the page under electrical: ignition
Hope this helps!
Old Jan 5, 2007 | 12:46 PM
The Black Machine 29's Avatar
do you have an aftermarket radio? if so make sure your monster cable is grounding out somewhere it shouldnt be.. lol that happened to mine
Old Jan 5, 2007 | 02:36 PM
i see theres a lot of reasons it could b doing this
precious1979
Dec 12, 2012 08:12 AM
Val1970
Oct 25, 2012 04:14 PM
70monte1
Dec 7, 2010 09:12 PM
StanzManianDevil
Dec 30, 2008 10:32 PM
Pineapple
Nov 24, 2007 04:14 AM
