Window Mystery? 01ss
Old May 14, 2006 | 03:58 AM
Mshaginaw's Avatar
Default Window Mystery? 01ss
O1 SS
Ok Right now my passenger window will not go down up or anything by either the drivers switch or the passenger switch. At night when you press the switches you can see it dim out the guage lights a little like its tryin to come down so i think the switches are ok. once out of about every 30 times in the car it will work fine but the weird thing is now my drivers side window is starting to do this off an on. So here are a couple questions. Is the drivers switch totally master over passenger switch? How do you reset this window breaker if its even possible? any ideas? sorry if this a repost I searched
Old May 14, 2006 | 10:31 AM
montejass's Avatar
Default RE: Window Mystery? 01ss
I'd be willing to bet that the driver side (master) switch('s) is bad..
Old Jan 4, 2007 | 01:40 PM
01pacecaredition's Avatar
where can you find the driver side master swithch ?
Old Jan 4, 2007 | 01:43 PM
benhillzone3's Avatar
either the master switch is bad or the window motors are faulty and going out
Old Jan 4, 2007 | 01:46 PM
wiz kidd's Avatar
thats what i was thinking is that the motor is gone in the door
and if that is the problem they are available aftermarket so you dont have to pay a fortune @ the dealership
Old Jan 4, 2007 | 04:16 PM
01BlkSS's Avatar
I was also thinking something with the motors, but I was thinking along the lines of maybe a bad ground. I had the same problem in my suburban and come to find out it was a bad ground. Haven't fixed it yet, but when it acts up, I pound on the door a couple of times.
Old Jan 5, 2007 | 12:40 PM
The Black Machine 29's Avatar
my monte has the same problem... the passenger side does not go down i think this should be some kind of recall or free fix on the chevys because it happens to alot of them
Old Jan 5, 2007 | 02:41 PM
check your motors guys but start wit da ground first since dats easier
jeffsmonte
Nov 21, 2022 07:34 AM
Andy2001SS
Oct 9, 2012 07:53 AM
callie100
Jun 16, 2012 11:28 AM
Dredd
Dec 14, 2009 02:32 PM
TrapShooter8
Jun 3, 2007 08:31 PM
