6th Gen ('00-'05): Slipping Transmission only when turning
Old Oct 27, 2022 | 04:45 PM
doit4dale's Avatar
Default Slipping Transmission only when turning
2005 Monte Carlo SS 3.8 S/C 158,624
Ever since I bought the car with 127,xxx miles the car did not feel like it shifted right. I ignored the problem because it only shifted hard when I was barely touching the throttle, I mean to be expected with a 20 year old car. Now the car sometimes feels as if its trying to find the gear its supposed to be in. Delayed but relatively smooth shifts are common while unexpected very violent shifts are rare but do occur. I have no clue where to start. The car has now 158,xxx miles. Has a check engine light that was checked while back that was a sensor (drove fine for almost a year with the light on). ABS and traction control lights are also on. Today I pulled out of a inclined T intersection and the wheels were turned slightly past 45 degrees. The car was fine until about 2200 rpm in first gear and completely revved out and lost the gear, I had enough momentum to straighten the car and once the wheels were straight it shifted from 1st to 2nd a little hard but what I would consider normal.
Old Oct 27, 2022 | 08:19 PM
How is the fluid level?
Old Nov 1, 2022 | 08:44 AM
When was the last time the fluid in the Trans was changed, this should really be don about every 60K and if it was never done this would be a good start point.
Old Nov 4, 2022 | 12:45 PM
doit4dale's Avatar
Was low.. dropping the pan this weekend and replacing filter. We will see if that helps
Sanjay Collins
17
Aug 16, 2012 09:49 AM
silvermike19
Dec 15, 2011 05:54 PM
GYROBLEU
Jul 19, 2010 10:00 AM
S_DAHM
13
Jul 1, 2009 12:42 AM
Z34 in the Couve
Jan 28, 2009 03:18 PM
