Signal light issue
Old Sep 9, 2012 | 11:33 PM
MRagland828's Avatar
Default Signal light issue
Hello all:
I have an '06 MC with 3.5 flex. Recently, I have been experiencing turn signal light issues. When I go to hit the left turn signal the light and clicks (from the dash) will occur let's say once per second (or whatever the normal speed is) and then increase rapidly to twice per second. Also, I noticed that the constant day lights will illuminate on that side but the brake light and blinker will not. If I remember correctly, the top bulb is for the blinker which does not work at all. The bottom bulb has two filaments; one for constant lights and the other for brakes. However, only the brake portion does not work. Does any know what causes this problem?
I have read other threads about the turn signal switch but my lights and clicks are fine (from the dash). Unless, that is a sign that it's going bad. I just do not understand why it stops only the left brake light and both front and rear driver side turn signals. Also, I'd like to add that I have replaced all the bulbs. Lastly, when this issue occurs the opposite reverse light goes out. Weird...I know.
Any ideas, insight, and tips are greatly appreciated.
Thank you.
Old Sep 9, 2012 | 11:43 PM
Originally Posted by MRagland828
Hello all:
Thank you.
I vote for a new flasher relay.../..possible ground issue....
Have the wireing for the lights and flasher for continuity...resistance voltage etc...
That should tell you what the "real" problem is...
also the 2 element bulb is for turn signal, running and brake light...
Old Sep 13, 2012 | 07:22 AM
03SSLE's Avatar
Even though you replaced the bulbs I would double check them. When a bulb stops working it changes the resistance in the circuit. This change in resistance is what causes the indicator to flash at a faster pace. The front bulb is a 4157NA and the rear is a 3057. While you are checking the bulbs have a look at the sockets to insure there is no build up of dirt/oxidation on the contacts.
Little Cheese
Feb 15, 2015 06:11 PM
Jeherr
Oct 6, 2012 05:08 PM
DCWZen
Sep 12, 2011 08:44 AM
bikerboyzzky
Aug 9, 2011 12:00 PM
gdogg090
Jun 25, 2011 03:16 PM
