Service traction??
Old Apr 25, 2010 | 01:11 AM
joedaslik's Avatar
Default Service traction??
Quick question, Once and a blue moon my '06 will post a "service traction control" on the screen..It happened about 3 times in the past year and I have plugged it to the computer but nothing came up..Has anyone else had this problem?
Old Apr 25, 2010 | 07:57 AM
04MonteLS's Avatar
I have, but I think it had something to do with me removing my factory deck because ever since it's been back in I haven't had that problem, imagine that.
Old Apr 25, 2010 | 10:31 AM
monte07's Avatar
your best bet is go to a shop that has a scan tool that is gm tech 2 tool. they will be able to get all of the codes and to check every thing the averege hand held scan tool from autozone and advaneauto will not read every thing. on the second thing it might be a wheel bearing might be going bad as in the sensor in the hub might be going bad. and the whol thing might be neding to be replaced.
Old Apr 25, 2010 | 08:54 PM
joedaslik's Avatar
Thanks guys, I will definitely be getting it checked out.
Old Apr 25, 2010 | 09:01 PM
mak330's Avatar
i believe from reading up on this problem if you only have the problem seldomly it has to do with your wires or abs module.
you can take it to a shop and they will tell you what wheel it is for a fee. if the shop knows what there doing, they can take a volt/ohm eter and check at different points in the system to see where the problem lies.
ive heard people say b4 that their mechanic couldnt do anything unless the light was on. so GL
personally ive it was me i wouldnt worry about such a random, not permanent problem.
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
GSchroeder
Sep 25, 2009 07:57 AM
TGAbreu
Jun 7, 2007 08:32 PM
gbergkamp
Nov 21, 2006 09:53 PM
