Service Engine Light came on
So today my "Parking Brake" light came on so I popped the hood and noticed the sensor that goes into the brake fluid reservoir was hanging out, so I disconnected the sensor and pulled it out of the reservoir, the light did turn off. My question is if I disconnect the sensor would it cause the "Service Engine Light" to turn on? My engine runs great no problems at all
Since the PCM probably relies upon a signal from the sensor I suppose that disconnecting it could trigger the CEL. The only way to know for sure is to retreive the code(s) and see exactly what triggered the light.
Glad to hear you came back from the "Dark Side"
So went with another W-Body?? I hope the GTP pans out better then the Monte did for you (I recall that you liked the Monte, but it was giving you some issues).
Anycase, what ever the motivator was, welcome back!!
hey i have 3 pods guage pillars for the gp if you plan to mount one come with autometer black face boost, trans temp, and oil temp guages. pm me if you interest
Deadsnake
Mar 8, 2014 08:21 AM
Chris s
Jan 27, 2013 04:30 PM
