7th Gen ('06-'07): Seat Heater Not Staying On
Old Apr 5, 2014 | 12:04 PM
I'm thinking similar to 03SSLE, a possible circuit breaker. The symptoms you are describing kinda match what my Monte and wife's Impala did with the rear defroster (it might activate for a moment, just enough to show the grid lines and then stop).
I found it was a worn out circuit breaker. Replaced it and the defroster has been working great ever since. Not sure if the seats have separate breakers, but if they do, stands to reason that could be a possible issue.
Old Apr 5, 2014 | 03:32 PM
joeykl66's Avatar
yep mine still not fixed. lol
Old Apr 9, 2014 | 06:47 AM
Originally Posted by WannaMCSS
Has anyone been able to figure out and or fix the issue?
No, I haven't even started looking into it. I will at some point but it's not really a priority since I don't drive the car in the winter.
Old Apr 9, 2014 | 09:44 AM
Aaron0313's Avatar
If you don't mind a newbie taking a stab at it... sounds like it might be something with the heated seat control module or thermister where the relay that turns that on is not staying latched. Perhaps the thermister thinks the seat is up to temp already and turns off the relay via the sense input to the control module. I've attached the wiring diagram for the driver side circuit for 2000-2005 (I suspect 2006+ is similar).
Old Dec 19, 2023 | 01:32 PM
Kelly Stady's Avatar
Bump... still looking for any insight into this.
yes my passenger side is broken I need to replace the switch driver side works fine 05 Monte Carlo SS supercharged
Default 2005 Monte Carlo SS supercharged passenger side seat heaters switch
I have part number 6945-002 but they tell me it has to be an eight digit number
Old May 4, 2024 | 05:21 AM
gpanderson7631@comcast.net's Avatar
I'm having the same problem ten years later. Does anyone find a solution?
Tiger Joe
Dec 19, 2024 04:15 PM
seawolf18
Sep 13, 2010 04:18 PM
jimbo7
Dec 3, 2009 03:05 PM
J_Bru_Ha_SS
Dec 16, 2008 08:13 PM
jeff2425
Dec 6, 2008 04:16 PM
