6th Gen ('00-'05): SDM replacement question
Old Jul 1, 2014 | 08:41 PM
Aaron0313's Avatar
Default SDM replacement question
The 2002 3.4L had an airbag light. I read the DTC and also had a dealer read the codes and it came back to a faulty SDM. I replaced the SDM with one with the same part number on the top from a local junkyard where the car did not have airbag deployment. The airbag light remained on so I checked power ground at the wiring harness for the SDM (with the SDM disconnected) and all was ok there. I read the DTCs again and it seems to point to that the SDM/BCM combo needs to be programmed to the vehicle.
Is that accurate that the SDMs need to be programmed to the specific vehicle and is a dealer able to reprogram a used module or does it need to basically be a module that's blank or never programmed to a vehicle?
Old Feb 2, 2021 | 06:57 PM
GrayGhost1951's Avatar
Did you ever get it fixed? I have the same problem.
classicrocker883
Apr 23, 2019 09:07 PM
TexasDvlDog
Feb 9, 2015 08:06 PM
Josh Rovou
Oct 11, 2013 05:58 PM
Brandon Thompson
Apr 5, 2013 05:30 AM
DE02Carlo
Jun 2, 2012 09:28 PM
