01 bcm module
Old Mar 31, 2013 | 11:31 AM
Brandon Thompson's Avatar
Default 01 bcm module
occasionally my battery light will come on and voltge meter will drop to 0. checked battery and alternator so i'm guessing bcm? Also the bcm u get from parts house is plug and play right> other than the programing dealer would do like mileage and vin.
<object style="position:absolute;z-index:1000" type="application/x-dgnria" id="plugin0" height="0" width="0">
</object>
Old Apr 3, 2013 | 05:43 AM
aussiek2000's Avatar
No, it must be programmed. Car wont function/start if you just plug it in.
Old Apr 5, 2013 | 12:37 AM
Really!? Someone forgot to tell the BCM that! bought one from autozone $94 installed it, reset security crap and problem fixed!!!! Only thing that doesnt work is airbags cause vin on BCM doesnt match.
<object style="position:absolute;z-index:1000" type="application/x-dgnria" id="plugin0" width="0" height="0">
</object>
Old Apr 5, 2013 | 05:30 AM
It was probably already programmed being a reman BCM or customer return. A new one from GM is blank and will not do anything.
DE02Carlo
Jul 4, 2012 10:07 AM
kweef
Mar 9, 2008 07:39 PM
jogasz28
Jan 29, 2007 05:06 PM
keghead40
Jan 7, 2007 03:08 AM
orthokneepa
Dec 2, 2006 12:19 PM
