screen on TB
screen on TB
Hello can anyone tell me what the screen is for on the T.B.? I did the Upper/Lower intake gaskets (leaking oil into combustion chamber) replaced the upper intake with the new and inproved version and noticed the screen on the TB, kinda strange,,Thanks Mike
In addition, I read some debate about the screen having to do with making the air enter the UIM in a linear fashion and some other design stuff related to how it gets the air and fuel mixed together.
I thought you were just talking about MAF readings. I thought it had something to do further downstream from the MAF....
Sorry, it's been a LONG weekend.
If you have the stock intake box I would recommend keeping the screen on to "straighten the flow" (as others have said)
I personally chose to leave mine on. Some believe that it is a restriction and is not needed if one has a smooth intake which could straighten the flow of the air without needed the screen.
I haven't seen any data that supports removing it will increase flow.
However when I did a TB upgrade, ZZP recommended I remove my screen and retune the car, but if it stumbled a lot to put the screen back on.
Intake Designs, Airflow Testing and Theories | | ZZP NewsZZP News
CFM w/ 1" of vacuum.
168 LS6 MAF with screen in
191 LS6 MAF w/o screen
94 Stock GT TB with screen
104 Stock GT TB w/o screen
107 Stock GTP TB with screen
119 Stock GTP TB w/o screen
123 S1 GT HVTB w/o screen
138 S1 GTP HVTB w/o screen
With that said, for the majority of people, I'd just leave it in.
