screen on TB
Hello can anyone tell me what the screen is for on the T.B.? I did the Upper/Lower intake gaskets (leaking oil into combustion chamber) replaced the upper intake with the new and inproved version and noticed the screen on the TB, kinda strange,,Thanks Mike
The screen straightens out the airflow for the MAF sensor to get a proper reading.
(Post 463953)
Is that the same way to said what I did?
I thought you were just talking about MAF readings. I thought it had something to do further downstream from the MAF....
Sorry, it's been a LONG weekend. |
(Post 464046)
and some other design stuff related to how it gets the air and fuel mixed together.
Originally Posted by jimbo7
(Post 464078)
makes chibi's remark invalid and makes him look like a prick
If you have the stock intake box I would recommend keeping the screen on to "straighten the flow" (as others have said)
I personally chose to leave mine on. Some believe that it is a restriction and is not needed if one has a smooth intake which could straighten the flow of the air without needed the screen. |
I haven't seen any data that supports removing it will increase flow.
However when I did a TB upgrade, ZZP recommended I remove my screen and retune the car, but if it stumbled a lot to put the screen back on. |
(Post 464201)
Intake Designs, Airflow Testing and Theories | | ZZP NewsZZP News CFM w/ 1" of vacuum. 168 LS6 MAF with screen in 191 LS6 MAF w/o screen 94 Stock GT TB with screen 104 Stock GT TB w/o screen 107 Stock GTP TB with screen 119 Stock GTP TB w/o screen 123 S1 GT HVTB w/o screen 138 S1 GTP HVTB w/o screen With that said, for the majority of people, I'd just leave it in. |
