running a little hot
Old Feb 4, 2015 | 09:27 AM
dave countie jr's Avatar
Default running a little hot
what is the normal temp on a 3800 run? the temp gauge is a little past 1/4 when im on the highway pretty normal right?but when I stop at a traffic light or when the car in not moving the gauge goes up past half and sometimes a little more. the coolant level is good and both fans are on .any thoughts? Btw I run green coolant.
Old Feb 4, 2015 | 09:54 AM
Maybe...
Theres air in the system. Would be my first guess.
Have you had any leaks in the past or currently?
I would try bleeding the system to be sure there isn't any air in the system..
When you changed the antifreeze... Did you flush the system completely?
It may mean the thermostat isn't closing.. maybe you need a new T stat?
Old Feb 4, 2015 | 10:34 AM
yes it flushed. how do you bleed air out? is there a you tube on this? how hard is it to change a stat? i got to get this resolved before this snowstorm hits St Louis.
Old Feb 4, 2015 | 10:53 AM
Run the car until its at operating temp.
Turn it off... on the gooseneck (T stat housing) theres a bolt/nut... turn it counter clock wise slowly and let the air seep out.. when you get fluid coming out. close the nut/bolt... restart the car (To rebuild pressure) for a cpl minutes.. Then re peat the process.. It may only take 2 or 3 times to get all the air out. and or possibly up to 10 times.
Me personally..
I Would start with a minimum of 3 times doing this process.
Then drive it like you would normally and see if theres an improvement...
Does your vehicle have good heat now? or does it come and go?
(DO NOT DO IT WITH THE MOTOR RUNNING)
Old Feb 4, 2015 | 11:06 AM
Sounds pretty normal. Do you have a 180* thermo in? Because that's about 1/4 on the gauge. Then the stock tune has the fans come on at 212, which would be a little past halfway.
Old Feb 4, 2015 | 11:26 AM
the heat is HOT and does not fluctuate. I don't know what temp stat I have I think it a 190?? IDK.yes chibi the fans do come on so does that mean it is to the boiling point? I took the cap off and noticed air bubbles working their way out. so I put a little more antifreeze in and let it run for 10 min or so.put cap back on and let cool for awhile. getting ready to go run it down I55 here and ill let u know how he does. BTW how do turn on the emojis?
Feb 1, 2013 07:35 AM
polososa
Mar 2, 2010 09:11 AM
mothernature22
Jul 19, 2008 10:03 PM
mothernature22
Jul 17, 2008 12:10 PM
allprorock
Oct 9, 2007 02:09 AM
