6th Gen ('00-'05): 03 Monte has sat for 2 years.. need some advice!
Old Feb 6, 2015 | 06:58 PM
Paul Kizer's Avatar
Default 03 Monte has sat for 2 years.. need some advice!
The love of my life has sat for 2 years and been neglected other than being started a few times. Got a couple problems now.. hoping someone could shred some insight to what i can do to fix it.
1) theres a leak somewhere in my car, theres water on the passenger floorboard and mold has formed in my car.
2) my grandpa went and started my car a while back and the key is stuck in the ignition.. it wont fully turn off and i think thats why the key wont come out, and of course the battery is dieing immediately afterwords.
and
3) this was happening before it sat for 2 years.. after it would heat up it would be hard trying to shift it into drive from park and vice versa.. But not while it was cold.. And sometimes it would shift hard untill i turned the car off and back on..
I realize i shouldn't have let it sit that long, but it was definitely my choice! and im on a budget so if its gonna be an expensive fix.. break it to me easy >.<
thanks for any help guys.
Old Feb 6, 2015 | 08:13 PM
Welcome the forum!!!
#1 might possibly be a leaking heater core
Old Feb 6, 2015 | 08:34 PM
el pachuco's Avatar
problem #1. click on the link below.
https://montecarloforum.com/forum/fw...rain+deflector
Problem #2. Try turning the steering wheel one way or the other while you turn the key to the off position. I know the key sometimes gets jammed when the wheel is turned too far, and makes it feel as though the ignition is screwed up.
problem #3. It might not be a bad idea to change your transmissions filter and fluid. How many miles on the car and has the service already been done before?
SteveCZ28
Jun 1, 2015 09:12 PM
crete
Sep 6, 2011 08:15 PM
waboss
Jun 23, 2008 10:16 AM
kingreyna
Nov 6, 2007 06:49 PM
mickey
Aug 23, 2006 05:31 PM
