Running Hot...
Old Jul 8, 2010 | 09:38 PM
sinceire's Avatar
Default Running Hot...
Went to crank her up today, and out of nowhere she starts running hot before I could even get off my street. My question is what are the usual problems with these engines that make them run hot? & just so you know my radiator is full, fans are both working, coolant is fine, and I haven check the thermostat but will in the morning. Thanks in advance.
Old Jul 8, 2010 | 09:40 PM
The Popcorn King's Avatar
I would check the T-stat. Sounds like its getting stuck shut.
Old Jul 9, 2010 | 01:56 AM
nitehawkjcb's Avatar
Do a compression test, your head gasket may be bad.
Old Jul 13, 2010 | 08:14 AM
nyislanders's Avatar
My monte was running hot last week as well. We replaced the thermostat and topped it off with coolant. You said your coolant is fine, so you should check the thermostat like others above suggested.
Feb 1, 2013 07:35 AM
polososa
Mar 2, 2010 09:11 AM
mothernature22
Jul 19, 2008 10:03 PM
mothernature22
Jul 17, 2008 12:10 PM
allprorock
Oct 9, 2007 02:09 AM
