Rich Fuel Mixture
Old Mar 16, 2007 | 09:32 PM
joesumrall's Avatar
Default Rich Fuel Mixture
Ok so here is the dealio. For about 8 months my 02 monte Ive had cranking issues where I have to stomp the gas pedal to crank it and always it idles inaccurate and sometimes dies and the check engine light is on. Took to a mechanic and he gave me some bs about the fuel pump being week and I pretty much argued with him that it wasnt but he insisted. So he installed a knew one and it didnt work like I told him. The check engine light came back up so I took it to autozone and the code was rich fuel mixture could this be the regulator, O2, or idle sensor? Also how do I reset the message center without a factory radio?
Old Mar 17, 2007 | 04:22 AM
Mrrench's Avatar
Default RE: Rich Fuel Mixture
I would go with the fuel regulator and the o2 sensor.
Old Mar 17, 2007 | 10:45 AM
joesumrall's Avatar
Can Ohm the o2 To check it ?
Old Mar 17, 2007 | 01:58 PM
Mrrench's Avatar
Yes you can ohm the O2 sensor out. I dont have the spec's for at home.
Keep in mind when you first start the engine cold the O2 sesnor will tell the computer to make the car run rich until it heats ups.
If you are having to hit the gas pedal to start the car, you are putting more air into the engine. Its sounds like it is getting to much fuel which is control by the regulator. If the regulator goes completely bad the only thing that it will do then is dump fuel into the cylinders and flood it out so it will not restart at all.
When this happens you will need to replace the regulator plus the sparks plugs.
Old Mar 17, 2007 | 06:22 PM
joesumrall's Avatar
Gas does come out the vacum when I unhook it from the regulator after a few seconds is this normal on GM's or should it not spit gas out at all?
Old Mar 17, 2007 | 09:51 PM
Mrrench's Avatar
Nope
No gas should come out
Old Mar 18, 2007 | 06:58 AM
z34phoenix's Avatar
yeah fuel coming out the reg is a sign of a bad regulator.... i would first remove the regualtor to make sure the O rings are in place and not damaged.... but chances are its shot.
Old Mar 20, 2007 | 12:44 AM
joesumrall's Avatar
Ok I took the regulator apart and the o-rings looked pretty good. How hard is it to replace the regulator?
Old Mar 31, 2007 | 04:34 PM
joesumrall's Avatar
Today I finally decided to replace the regulator after taking it took a so called mechanic and charging me 500$ and not fixing the problem I spent 80$ on a regulator and it seems to be doing fine.Thanks for all the help Guys!!!
Old Apr 1, 2007 | 11:59 PM
04 Intimidator's Avatar
Glad to hear it's fixed. I would keep that experiance in mind with that dealership in the future.
85v6
Oct 6, 2020 11:16 AM
Dstevens
Dec 27, 2012 08:37 AM
satara_edem@hotmail.com
Dec 22, 2009 10:59 AM
S_DAHM
Jul 8, 2009 10:59 PM
jcappsiv
Mar 2, 2009 12:33 PM
