6th Gen ('00-'05): New computer burns fuel rich/lean?
Old Dec 18, 2012 | 07:05 PM
Dstevens's Avatar
Default New computer burns fuel rich/lean?
Just making sure this isnt to much of a problem. After zzp computer install I started using 91 octane and I can tell my exhaust smells a little weird. I have a friend with an alero that smells the same. Is it just running rich or lean? or maybe Its the new down pipe with the high flow cat. I dont know.
Old Dec 19, 2012 | 07:53 AM
Most likely you are running rich because it is safer to tune a little rich on a mail-order-tune.
Old Dec 19, 2012 | 12:23 PM
Dstevens's Avatar
OIC. thank you Chibi
Old Dec 22, 2012 | 07:41 PM
Bait's Avatar
Easy one I'm sure but should a wideband O2 sensor be installed first, or will the tune compensate for that?
Old Dec 27, 2012 | 08:37 AM
A wideband only tells the tuning software the mixture of air and fuel so that you can adjust accordingly.
Unless you are tuning at that current time, it doesn't need to have a wideband on the car.
sal23
Jul 9, 2013 05:46 AM
S_DAHM
Jul 8, 2009 10:59 PM
RickAKATed10
Jun 2, 2009 11:29 AM
BeachBumMike
Jan 26, 2008 08:36 PM
joesumrall
Apr 1, 2007 11:59 PM
