Remote Starter?
J/K
Is that without the key in the ignition? if so, That's suppose to happen.
I have a Crimestopper Alarm and Remote Start and I wired it myself.
For most if not all aftermarket remote starts, you need to insert the key and turn it to the "ON" position so that the anti-theft security does not kill the engine . The remote starter has a bypass module for the anti-theft security, and will temorarily bypass the security to start the car. The remote starter would not start the car if it did not bypass the anti-theft security during starting. When you touch the brake with out the anti-theft security seeing the key, it then does a safety shutoff/kill. The anti-theft security still needs to see the key in the "ON" position for you to take over.
There also should be a "Anti-Grind" feature so if you do turn the key to far to the "START" position the starter will not engage. Try it with a quick turn and see.... so you know and are aware.
3rd Gen ('78-'80): Starter Solenoid for Summit SUM-G1660 Mini High-Torque Starter
rmorman
10-24-2013 06:32 PM
BHermes21
19
12-18-2008 10:45 AM
Kelt
03-15-2007 02:36 AM
