Rattle in the Rear
Old Apr 15, 2007 | 02:36 AM
uthminmel's Avatar
Default Rattle in the Rear
I have an 04 SS. I started hearing this rattle in the rear on the drivers side not too long ago. It rattles any time i go over a bump or hit a pot hole. Now though I am getting the rattle on both sides. I have not figured out where it is coming from. Anyone else had this issue?
Old Apr 15, 2007 | 08:51 PM
04 Intimidator's Avatar
Default RE: Rattle in the Rear
Welcome to MCF Melinda!!!
Can you tell us a bit more about the rattle? I have the same model and may be of help. Does it sound like its coming from the trunk, rear panels by the seat belts?
Can you be a bit more specific?
Otherwise I'd say get the junk out of the trunk.
Old Apr 15, 2007 | 09:00 PM
wiz kidd's Avatar
hey welcome to the site
is the rattle inside the car or outside ?? hey welcome to the site
Old Apr 15, 2007 | 10:22 PM
mickey's Avatar
welcome,
Check the rear struts. My moms grand am just did this to her also found out the rear struts were bad and one was lose so they replaced them both no more rattel. Good luck hope you find it
I hate rattels in my car[:@]
Old Apr 16, 2007 | 06:37 PM
ww's Avatar
ww
Im pretty sure I know this one! I had a rattle just the same as yours and when I told my mechanic what was happening he said it was the two 6" rods that connect the anti sway bar to the rear end. I ask him how he knew this over the phone and he said these go out on Chevy's alot. He was right, the set of two cost me about $20.00 and that solved the problem. The reason Im so sure this is the same as my problem is one side started to rattle and within aweek the other side started.
Gib
Nov 20, 2012 09:45 PM
PoGo86
Jul 1, 2009 07:54 AM
DJ-Sincro
Apr 1, 2009 07:04 AM
prez
Dec 29, 2006 06:55 PM
ralphtrent
Sep 22, 2005 01:56 PM
