6th Gen ('00-'05): Radio Not Working
Old Feb 19, 2023 | 01:49 PM
DonVincenzo's Avatar
Default Radio Not Working
Hey everyone, just looking for some help diagnosing a radio issue on an ‘01 Pace Car that I just bought. (Actually have another one but that was my daily use car so it took a real beating. Got the newer one at a great deal with only 12,000 miles on it so I’m keeping it as my collector/show car.)
There is no sound currently from the new one’s radio whatsoever. Nothing from the AM/FM radio, nothing from putting in a CD (although you can hear the mechanical parts spinning/reading and skipping tracks perfectly normally,) and perhaps most strangely not even the door chime. The RDS works fine as it shows the correct station/song info, can program the station presets into the memory and it holds it, but no sound at all, not even the beep/chime to confirm setting changes or when the door is ajar with the key in or even warning chime that seatbelt is unbuckled etc. Just silence.
My father is a mechanic and figures most likely culprits are the amp in the trunk or just the radio unit itself? I don’t mind sending it out to be rebuilt if that’s the problem but I have a functioning amp in my other Pace Car; should I try popping that one in to see if it makes a difference first before taking the dash apart and ripping out the radio? Anyone know if the amp would affect the chime’s ability to function? Or does that just prove it’s definitely the radio unit itself? My father is worried about putting my other amp in without knowing for sure that’s the problem just in case something happens to that one after we try.
I’ve asked the previous owner about the issue and she said it started a couple years ago with the sound going in and out every so often and then eventually just the constant silence. She took it to the dealer but apparently they couldn’t be bothered because of the car’s age. They told her “the connections seemed ok but it was too old to be reprogrammed” so they “couldn’t be of any help.” The car was garage kept it’s entire life and according to the previous owner only saw rain 2-3 times in it’s lifetime and that was recent; just the last 3-4 weeks when it was on the lot for sale. (I.E. long after this problem started.)
Any help/insight anyone can provide would be appreciated!! Thank you!!
Old Feb 21, 2023 | 08:13 PM
I would honestly start with checking fuses. If those are OK, if you have a known good amp, sure, swap them and see what happens. My guess is it is something related to the amp (either a bad amp or a bad power/ground connection).
Old Mar 14, 2023 | 11:07 PM
Swapped the amps and that solved the problem! Fully functioning radio again!
Now my curiosity leads me to wonder (and seek opinions) on what would be better to have as a backup in case this happens again: have the dead amp repaired (found a place able/willing via the internet) or just get another functioning one (albeit used) from a junkyard? Obviously the junkyard is cheaper but I care more about quality. My father has expressed concerns that the company that produced the amp makes a difference. We’ve been debating whether rebuilding the original (dead) Matsu****a amp would be more or less reliable than getting a used but functioning junkyard amp manufactured by Panasonic instead? (Which is the type I swapped from the other car.) Seemingly those were the two main companies to produce the amps for the car. There may even be others but I’m not aware of them.) Anyone have experience in the reliability of these amps? Thank you!!
Old Mar 15, 2023 | 09:56 AM
What's the price delta? Id imagine the junkyard parts are dirt cheap as long as you can find one. Id think you'd be hard pressed to even cover round trip shipping for what our local junkyard sells stuff like that for (especially on the sale days).
Youd probably have to get an electrical engineer to look at the boards on the two side by side to say if one is higher quality than the other. I don't know that your original would necessarily be any better or worse quality after repair. Certainly the piece they fix will be better, but maybe the OEM used cheaper components across the board?
Matsu****a
Just found it funny the system auto censored part of the brand name.
I wish I would've known there were two brands back when I did car audio. We had a lot of montes / Impalas come through for aftermarket stuff due to bad stock amps - would've been interesting to see if the failure rate was isolated to one brand (I just assumed they were all made at the same place).
Old Mar 15, 2023 | 12:56 PM
dlinger's Avatar
Remanufactured one - https://www.1factoryradio.com/produc...-part-10309547
Edit - looks like it is unavailable.
Old Mar 15, 2023 | 04:37 PM
I used car-part.com to search junkyards across the country and then called a few local ones myself. Nobody nearby to me has one so looks like shipping is the only option. Seems like the going junkyard rate is anywhere from $75-$125 without shipping. The quote I got for a rebuild was $175 with shipping and comes with a 1-year warranty. Considering no junkyard will even guarantee the one they provide will even work (let alone last at least a year) I'm leaning towards the rebuild to be safe. In the grand scheme of things after adding shipping costs for a junkyard one it doesn't seem like all that much more to have some peace of mind that it will work and hopefully last lol.
Old Oct 18, 2023 | 06:38 AM
Jessejeb's Avatar
Default Need Reman Info for OEM Amp
Please provide the information for the vendor who repairs these amplifiers. We have two 2005 Impala vehicles with no sound. Our 2005 Monte still works just fine. Would like to try the amp route first before purchasing head units. Thank you.
Old Oct 18, 2023 | 06:42 AM
Here’s the info:
Joe Flaherty
OEM Auto Audio Inc.
President
jflaherty@oemautoaudio.com
315-430-8087 (call or text)
8043 Broadfield Road
Manlius, NY 13104
OEM Auto Audio Inc.
Old Oct 19, 2023 | 06:23 AM
Jessejeb's Avatar
Default Info for OEM Amp
Outstanding!! Appreciate your fast response! Will put info in our file for future use.
Purchased two amps on eBay – one from salvage yard and it was DOA. Second one had been tested and also had a warranty.
Second one put sound back into one of the two 2005 Impalas.
Wen shopping the internet or eBay, would suggest purchasing only when the seller offers a warranty and has tested the unit.
Found OEM Auto Sound and purchase another amp to attempt to fix second 2005 Impala. Will post results when it arrives.
Here is the link: www.oemautosound.com
Also found Original Car Audio: www.cd4car.com
Jask Auto Parts: https://jaskautoparts.com/jask-used-...ers/index.html
All offer warranties. Hope this helps fellow members!
spamdaddy
Oct 6, 2022 03:03 AM
griffseefeld
Jun 16, 2022 12:42 PM
avendo
May 18, 2015 06:52 AM
TMoney
22
May 5, 2014 09:58 PM
pcwb
Dec 13, 2008 06:35 PM
