RDS vs non- RDS radio
Old Jan 18, 2022 | 02:13 PM
spamdaddy's Avatar
Default RDS vs non- RDS radio
Hey everybody. My current radio (non-RDS) in my 05 SS-SC, plays but is very weak. I tried swapping factory amps with no better result.
I assume the head unit should be replaced. Would it make a difference if I installed a radio that showed the RDS logo on the faceplate when my current radio does not?
Thanks in advance.
Old Jan 21, 2022 | 09:55 PM
If you are keeping factory head units, you can swap a bunch of different ones. I am actually using MP3 unit offered in the Cavalier and Venture Van. But, an issue that you will have is needing to get it unlocked/programmed with a GM Tech II. Before doing all that, have you checked the fuse that powers the amp? Validated the amp is getting 12volts and proper ground? If not, I would start on that before swapping the radio.
Old Jan 22, 2022 | 06:26 AM
spamdaddy's Avatar
Default RDS radio
I’ve checked fuses, but not the ground. I have swapped amps and gotten the same low volume result.
I am swapping the radio anyway due to the buttons on the current radio are mostly worn off.
Thanks for the input.
Old Feb 27, 2022 | 06:56 AM
spamdaddy's Avatar
Default Radio/amp replacement
Update. I replaced the head unit with the same result, so I contacted a buddy with an 03 that had a perfectly working radio system. He let me connect his amp to my system. SUCCESS!! Turns out the replacement amp was bad also. I hit the U-Pull It and scored 3 working amps for 02-05’s and 1 for 00-01’s. Now I’m rocking my tunes and kept a stock dash and sound system.
Old Feb 28, 2022 | 11:29 AM
Awesome! Always great to find and fix the problem
Old Oct 6, 2022 | 03:03 AM
koladx's Avatar
The problem is, your reciever, like many others (especially older or cheaper) can only display PS. So many stations usually dump the all of their information there. I'm 90% certain those with static message send the rest of stuff over RT.
192.168.100.1 192.168.1.1
96z34man
Oct 18, 2016 06:22 AM
96z34man
Oct 15, 2016 07:15 AM
avendo
May 18, 2015 06:52 AM
dmfonline
Oct 25, 2010 05:27 AM
sunset_ed
Oct 19, 2009 03:29 AM
