Radiator flushing
Old Jul 5, 2008 | 07:10 PM
03 monte SS's Avatar
Default Radiator flushing
Does the radiator on a 2003 SS 3800 have a drain or petcock? Or do you have to remove the bottom hose to drain the radiator?
Old Jul 7, 2008 | 07:31 PM
manny's Avatar
Default RE: Radiator flushing
good question.i want to do the same thing.......hope someone knows the answer?
Old Jul 13, 2008 | 11:29 AM
purewhitemonte's Avatar
The radiator willhave a drain plug if the radiator was equipped with it. It's located on the driver's side in the bottom back corner. Once the fluid drains out, you can proceed withdraining the fluid from the lower hose which would be step to take if the drain plug is not there.
It will also be possible that the thermostat housing may have an air bleed screw on it as well.Take a screwdriver and backit out 2-3 times toallow air in before doing the draining, so the the fluid can drain out better. The screw would be loosened after removing the radiator cap on the radiator. All this being done with the engine cold of course.
Old Jul 23, 2008 | 05:13 PM
04 Intimidator's Avatar
Also take off the radiator cap to help allow air into the system.
Old Jul 23, 2008 | 07:24 PM
manny's Avatar
after its all drained out .is it ok to hose the crap out of the rad.to clean it all out?........im doing mine this weekend?...........my rad liquid is PINK OR RED LOL.should i kleep that one or is it ok to change it to the green?
thank alot
Old May 24, 2011 | 10:18 AM
05JLMonte's Avatar
I took dex cool out of my system 3 years ago, no problems yet.
05 Monte LS 88k
Old May 26, 2011 | 01:24 PM
jjs777_fzr's Avatar
is there any environmental issue with letting the radiator fluid just spill out in the back yard ? I dont want to have folks get cancer later because I did something irresponsible. Otherwise I'll just take it to a garage and have them flush it for me. I also have the dex and will be swapping it with prestone 50/50 mix.
Old May 26, 2011 | 04:51 PM
jwjones's Avatar
Think about all the people who have busted their water pumps while driving and leaked all of it on the ground. You doing it isn't going to cause a world apocalypse.
Old Jun 29, 2011 | 01:48 PM
Shandley's Avatar
If an animal gets into your spilled coolant, they will surely die.
Old Jun 29, 2011 | 01:57 PM
Sparky-88's Avatar
No problem changing to green as long as you thoroughly flush all the old stuff out of your system. The two types don't mix well; they form a sludge. Fill with water / run engine 'til warm and coolant flowing through system / allow to cool / drain / repeat at least a couple times before pouring in the new green coolant. Or let a shop do a good power flush...
Thatboi
Nov 17, 2010 08:48 PM
Jack The Ripper
26
Aug 1, 2010 11:17 PM
monte quebec
Apr 16, 2010 02:24 PM
Feb 4, 2010 02:48 PM
RickCoMatic
Dec 9, 2007 09:15 PM
