`Flushing : )
Old Feb 4, 2010 | 07:46 AM
Question `Flushing : )
`Flushing
by
Flushing
Pat Goss
I was really shocked when I read an article in a major consumer-oriented magazine that said that certain types of preventive maintenance weren't needed, especially things like flushes.
Well, you know, one of the things that's very important toward keeping your car for a long time is to change the oil and change the oil filter and always use high-quality products as is recommended in the owners manual, but, above and beyond that, take a look at this new oil in the jar right here. Well, that new oil often becomes this mess of sludge that we see over here, because cars frequently need more than just the average oil change. See, here we have a valve cover that came off of a late-model automobile that had less than 50,000 miles on it. You can see it's completely coated with sludge. As a matter of fact, our sample over here came from the same car.
Fortunately, we were able to save the engine in this car for the customer, but in most cases there isn't any saving it. When it gets like this, the engine is done for. Now for comparison we have a valve cover off of one of our regular customer's cars. This one has 280,000- some-odd miles on it, and we have serviced it since brand new. Now you notice, the inside of the valve cover is virtually spotless, just a little bit of discoloration, no build-up whatsoever.
Both cars had oil changes, but the one with the clean valve cover, we have done something different for it, and this is where I take issue. This is an oil flush, or oiling system service. This particular machine is from BG Products, and it uses these chemicals to get rid of deposits that form in areas inside the engine, where oil doesn't really circulate. The oil just sits there. It congeals into sludge, the sludge breaks loose, then it blocks various passages. The blockage of the passages is what leads to this massive sludge problem. So, by using a machine like this periodically, 30 to 40,000 miles, you can double, triple, quadruple the life expectancy of your engine. So, it is money well spent. Something that I highly recommend.
Source: MotorWeek
Member's, what did you think of the above article ?
Did it help ? Do you `Flush your Engine ? ? ?
Post & let us know `ok
Old Feb 4, 2010 | 07:49 AM
Got 2 keep'em `Clean 4-Sure : )
Below are additional links on this Thread Subject:
Hope it helps someone...Good Luck
Car Bibles : The Engine Oil Bible
If you do decide to do an oil flush, first drain your engine of all it's oil, but leave the old oil filter in place. Next fill it up with flushing oil and ...
www.carbibles.com/engineoil_bible.html - Cached - Similar
How to Perform an Engine Flush in Your Car | eHow.com
For example, an engine flush might be useful in a relatively low mileage car with 30000-40000 miles that hasn't had its oil changed as often as it should ...
www.ehow.com › CarsCar MaintenanceOil Changes - Cached - Similar
Is Engine Flushing Necessary?:
The fact is, if you do frequent engine oil and filter changes and service the transmission every 15000 miles there is no need for a flush. ...
autotechrepair.suite101.com › ... › Auto Tech & Repair - Cached - Similar
Old Feb 4, 2010 | 10:13 AM
JaxJim's Avatar
Pat Goss is getting paid to endorse that product. If you change your oil every 3000-5000 miles, or whatever your car manufacturer requires, you will not have "massive sludge problems" as Pat describes.
Old Feb 4, 2010 | 02:48 PM
MAMONTE's Avatar
Engine flushes are NOT needed. Change your oil often, and your engine will look good inside. That sludged up valve cover is probably from a car that went 50,000 miles in between oil changes. My truck has 230,000 miles on it, and when you look in the engine filler cap, it is pretty clean inside there...certainly no sludge.
My Monte with almost 100K is spotless inside...with using synthetic oil and changing regularly.
03 monte SS
Jun 29, 2011 01:57 PM
Thatboi
Nov 17, 2010 08:48 PM
Jack The Ripper
26
Aug 1, 2010 11:17 PM
monte quebec
Apr 16, 2010 02:24 PM
RickCoMatic
Dec 9, 2007 09:15 PM
