Please Help Wiring Issue
Old Jul 26, 2013 | 06:39 PM
Originally Posted by Space
Hi Jerry, I did not want to sound mean either, but we need more infor to be able to help...I just couldn't think of any other way to answer.
I've asked some really stupid questions in life & so many I can't count on the MCF...I hope we get more information & that we can help our member will a good answer...
Peace/Happiness from `Space
Space I hope to get more info as to what is need . I rebuild alot of fuse blocks on mail trucks ..They burn out the hazard fuse alot because they use them..
Originally Posted by nikk2themax
how does a fuse block in a 85 MCSS get power?
It's feed it power from the battery.
Old Jul 27, 2013 | 10:51 AM
nikk2themax's Avatar
thanks for replies and im sorry my question was vague, i know it receives power from the battery i need to know which one and where is the main power wire?
Old Jul 27, 2013 | 01:26 PM
only straight wire from Big bat term on starter runs thru firewall to a switch, power wire from that same post on same switch ran to seperate starter switch. other post on "power" switch ran to fuse box BATT slot, other post of "starter " switch ran to starter solenoid. my box only received power (lights, signals etc) when "power switch" was on and ignition was in on position. Now with both switchs on i have no lights, no nothing. my main mindboggle here is where was my fuseblock receiving power? I ran that main wire from BATT term on starter to the wire running to the BATT slot to see if that theory was correct and results were still no power. This leads me to beleive that acted as a ground? and the power was from ignition being turned on?? The only reason i know both the "power" switch and ignition were required for fuse block activation was no lights unless both on and my elec fuel pump is wired to IGN slot on fuse block
Old Jul 27, 2013 | 01:27 PM
Default Wiring Help
Have no power to fuse block, please dont get lost. Thank to reply on here I now know 2 red wires in harness are supposed to deliver that power (constant and ign on) and are supposed to be wired to starter BATT term but my only straight wire from Big bat term on starter runs thru firewall to a switch, seperate power wire from that same post on same switch ran to seperate starter switch. other post on "power" switch ran to fuse box BATT slot, other post of "starter " switch ran to starter solenoid. my box only received power (lights, signals etc) when "power switch" was on and ignition was in on position. Now with both switchs on i have no lights, no nothing. my main mindboggle here is where was my fuseblock receiving power? I ran that main wire from BATT term on starter to the wire running to the BATT slot (previoslu on bottom of "power" switch) to see if that theory was correct and results were still no power. This leads me to beleive that wire acted as a ground for my "power" switch and the power was from ignition being turned on?? The only reason i know both the "power" switch and ignition were required for fuse block activation was no lights unless both on and my elec fuel pump is wired to IGN slot on fuse block, need help bad, THANK YOU
Old Jul 27, 2013 | 01:35 PM
Default Revised
MountainMan423
Apr 19, 2013 10:00 AM
Jparks
May 6, 2012 11:10 AM
mrcmos
Nov 20, 2011 11:36 AM
pipefighter
Jul 2, 2010 12:44 PM
mrl390
Mar 3, 2008 03:19 PM
