1998 z34 wiring issue
Old Jul 2, 2010 | 12:44 PM
pipefighter's Avatar
Default 1998 z34 wiring issue
iam looking for some help finding out where a wire is spose to go to. the other day check engine light came on and i checked the codes. the first was a series of codes for the map sensor. changed the map and rechecked..no more map codes, however i have a new code p0403 egr control circuit. i noticed while checking for loose wires, i found a purple/white wire disconnected. the wire comes off the engine harness from the d pin location on top of the engine near fuel rails and runs in its own conduit kinda by the master cylnder just beneath it, thats where i lose the connection. this wire puts a voltage .05v at idle and varies depending on what the rpms are. i was able to find out it could be fuel reserve signal wire but that it. the car has the 3.8. i spent many hours on this already plates are expired and cannot get them renewed till it passes emmisions. any help. would be greatly appreciated.
skramy
Jul 30, 2013 04:41 PM
buffbison82
Jan 9, 2010 04:27 PM
samuelkowal906
Aug 26, 2009 05:43 AM
lateralex426
Feb 5, 2007 08:57 PM
