Please help me!!!
Old Feb 2, 2019 | 08:49 PM
Izaiah Miller Sr.'s Avatar
Default Please help me!!!
I have a 06 monte carlo ss and it will not crank or after I replaced the battery
Old Feb 3, 2019 | 05:53 AM
Did you possibly touch the positive and negative terminals on the battery together? That would blow the fuse and cause this.
Old Feb 3, 2019 | 12:03 PM
I'm sure I did not
Old Feb 4, 2019 | 08:48 AM
Smile
Originally Posted by Izaiah Miller Sr.
I'm sure I did not
Well if it won't crank then it is usually and electrical issue of some sort. you have not given enough information to give a good diagnosis. So this is all guess work. Just wondering how many miles the vehicle has on it? Is it an inside or outside car?
Assuming that the battery was good even a new one can be junk any more? The battery should test out in the car with 14.2 Volts if you don't have that it won't start it.
Next the Starter if you removed it and reinstalled it maybe a wire was missed or broken I would double check that. Also if you have a bad ground it will not connect up.
Check all grounds. If they don't connect to bare metal some times they won't function. Grounds should also be cleaned periodically as well. Sometimes the ground gets corroded up at the battery and gives you fits.
I am attaching a link to google and this has all kinds of remedies for this issue check it out and you may get lucky!
https://www.google.com/search?source...10.kS9qCGFb2Lw
Old Feb 4, 2019 | 04:34 PM
thanks I'll look at it and I think it could be a fuse
Old Feb 4, 2019 | 07:24 PM
I'd second checking the ground. After that I'd check the connections on the starter itself to make sure they're tight.
Old Feb 7, 2019 | 01:53 PM
The only way I can get it started is by taking a little jumper wire from the positive on the starter and putting it in where you plug the other wire into the starter and it will start up that way..... I cant find the problem
Old Feb 14, 2019 | 09:21 PM
bullett's Avatar
It might be some type of security feature? Bad ignition switch? Electrical gremlin bud, if your not good with electronics your gonna have to find or pay someone that is. If its a security issue y
Prolific83
Jun 10, 2019 05:29 AM
cletisanne
Jun 9, 2014 10:55 PM
24_48Fan
Aug 31, 2010 11:54 AM
bubba
Apr 26, 2010 09:48 PM
ilitrit
Feb 9, 2007 04:38 PM
