Battery Corrosion
Old Aug 30, 2010 | 08:08 PM
24_48Fan's Avatar
Default Battery Corrosion
My 06 had some battery corrosion in which when I cleaned it up with some CRC battery cleaner that some of the underneath copper was exposed. It is the original battery but no starting problems yet. There are 22K on the 3.5. Should I be concerned? Should I replace the negative battery cable along with the battery? I have since out the red terminal protection on the terminal.
Old Aug 30, 2010 | 08:18 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
I had to replace the battery on my '06 SS and it was a huge PITA. Some of the research that I did before I put my work into the car indicated that the factory ground is not a very good one. If I were you, I would replace/relocate the ground wire. Good luck.
Old Aug 30, 2010 | 08:51 PM
do your own ground with a little larger wire, it will help with some of the dimming of lights and stuff, you can do it for your alternator too, for if you wanna do a stereo system. is there something wrong with the batter itself tho? just clean it off really, as long as the metal on the battery is connecting with the metal on the cable, you shouldnt have much of a problem.
Old Aug 31, 2010 | 05:41 AM
24_48Fan's Avatar
Just don' want the battery to fail and I concerned that about half of the tin coating is now gone from the negative battery terminal with copper now exposed. I was planning on doing the battery next May/June.
Old Aug 31, 2010 | 09:57 AM
ohh okay i see what your saying, as long as its not sparking or anything though i would think your okay for now, but i would look into a new battery sometime in the future
Old Aug 31, 2010 | 11:01 AM
24_48Fan's Avatar
I ordered a new negative battery cable and I will replace it when I do the battery.
Old Aug 31, 2010 | 11:54 AM
rj's Avatar
rj
I don't want to talk about the battery in my '06.
I've had to have it replaced a couple times already. And I barely drive the car. I constanly have to charge the battery to keep it up. Otherwise.............. it's dead battery time.
Franks 03SS
Apr 9, 2013 10:43 AM
zzapultimate
Nov 23, 2012 06:31 AM
labnjab
Sep 19, 2009 07:44 PM
DCfla
Aug 20, 2009 01:26 AM
odessadude
Dec 16, 2007 10:29 PM
