Starter or loose wire?
Old Feb 9, 2007 | 12:06 AM
ilitrit's Avatar
Default Starter or loose wire?
For the last couple days, when I crank my car up, it hesitates for a second, like the battery is low. Then it will crank up.
This morning when I tried to crank it up, it hesitated and went quiet. I turned the key again, and nothing happened. no, slow drawn out turn of the starter, not even a click.
I thought it might be my terminals being corroded. They were pretty ugly. I cleaned them as well as I could, using cokes. Still nothing. I tried jumping off with another car, and tested the battery, which was good. no luck.
Any suggestions? Is it my starter?
Old Feb 9, 2007 | 01:12 AM
DESS03's Avatar
Default RE: Starter or loose wire?
you know putting coke on there isnt good for your battery
Old Feb 9, 2007 | 10:19 AM
wiz kidd's Avatar
coke on a battery?? never heard of that before..they make spray stuff thats good for cleaning and keeping them clean...but never heard of anyone putting coke on a battery before....wierd
are you getting a clicking noise when you try to start the car or just no sound @ all???
easiest thing to do first is take the battery out and have it tested, if its not that then sounds like the starter...i think that if you can take it out autozone or someplace like that can test it for you...
if you live where its cold this is the time of year these things go
how old is your car??
Old Feb 9, 2007 | 11:04 AM
88ss408's Avatar
check your battery and battery cable connectors for corrosion bad connetion will result in a no start you should also check that all connections are tite and correct and also check your starter your solonoid mite be bad
Old Feb 9, 2007 | 04:30 PM
Mrrench's Avatar
Sounds like a starter issue
Coke and Pepsi is a good way of cleaning corded terminals...... just rinse it off real good
Old Feb 9, 2007 | 04:38 PM
wiz kidd's Avatar
but why waste good pop...well why waste good coke (dont really care about pepsi) on a battery, just get a can of spray stuff..lol..and use a wire brush on them
just never heard of using pop on termenils to clean them
rmorman
Oct 24, 2013 06:32 PM
Murray137
Oct 20, 2012 08:13 PM
jeffsmonte
Dec 10, 2007 06:46 PM
zipsayain
Mar 10, 2007 07:49 PM
wiz kidd
Jan 3, 2007 07:40 PM
