Please Help...
Old Feb 7, 2012 | 09:17 AM
How old is your thermostat ? It maybe sticking
A bad radiator cap can also cause problem's...Just a few things 2 check `out ~> Good Luck 4-Sure
Maybe you are playing your music 2 loud LOL..
I noticed that U R in2 music You should post your fav tunes in our Music thread !
Old Feb 7, 2012 | 03:39 PM
JaxJim's Avatar
Well, keep an eye on the coolant level - it should never go low, unless there's a leak somewhere.
Old Feb 29, 2012 | 10:00 PM
96_3.1L's Avatar
Well, She is back on the road. Intake gaskets blew!!! So, I had it fixed and tuned up.
Old Mar 1, 2012 | 04:13 PM
Reiska's Avatar
It's hard to figure out what you're concern is here. But if your temp gauge is reading really high, you might want to check the Coolant Temp Sensor. It might be dirty or just be a bad sensor. If it's just dirty, remove the CTS and check inside and make sure there is no debris or oil in there. After cleaning it, reinstall, and it should go back to normal, if not it most likely its a bad sensor.
And if your radiator coolant level is full and coolant reservoir is filled to the appropriate line, and you're certain of no leaks, yet your low coolant light still stays lit. You might want to check the Coolant Level Sensor. Also could be dirty or have gone bad. Once again remove it, clean it, and reinstall. If still not working, might want to replace the sensors. Clean before replace.
Old Mar 1, 2012 | 11:30 PM
96_3.1L's Avatar
Im saying it is fixed. It was my intake gaskets, it put water in my oil. So i had the "fix kit" put on. The car is performing ten times better than it was.
Old Mar 2, 2012 | 05:48 AM
blueSS's Avatar
Glad you got the problem solved
chevyONmine
Aug 1, 2023 07:33 AM
86monte carlo
Feb 9, 2012 07:46 PM
77gp
Jan 7, 2012 02:04 PM
Emnasty600
Jul 8, 2011 07:17 PM
