Phantom Electrical Issues! SOS!
Old Oct 15, 2013 | 10:37 AM
Dubstepticon's Avatar
Default Phantom Electrical Issues! SOS!
Having some crazy phantom electrical issues. When I go to turn the car on, sometimes nothing happens whatsoever. No attempt to crank over or anything. A faint whirring sound can be heard for a few seconds, only the CEL comes on, and then it just gives up. Like nothing happened at all. Usually happens with the earlier starts in the day.
And then other times when I go to turn the car on, and it does work, right before it starts up a pop or zap can be heard. This sometimes resets the clock on the radio to 12 or it shows a completely wrong time. This started happening about a month ago. I don't know if the battery is bad or not; I've had it for less than a year.
Today the car went to start, clicked a bunch of times rapidly, and like shorted out. The key fob wouldn't work, radio couldn't come on, no lights turning on in the car or on the dash, and it couldn't be started. I opened the door, and it kind of made a pssssttt sound, the security light came back on blinking, and then I could finally start the car.
SOS!!!
Old Oct 15, 2013 | 11:28 AM
Thumbs up Good luck
intermittent - Monte Carlo Forum - Monte Carlo Enthusiast Forums ...
Click above
2002 Monte Carlo will not start - Monte Carlo Forum - Monte Carlo ...
Click above
Chevrolet Monte Carlo Intermittent starting Problems & Solutions ...
click above
Hi 'Tyler, check above until one of our expert technical member's makes a post to help you > Good Luck 2 U & your S.S. <
Old Oct 15, 2013 | 01:18 PM
KCFITZ78's Avatar
I did not read any of the links SpaceRider posted...
With that said it could be corroded battery cables or loose main ground connection.
Check....
1) Check battery (engine off) with a multimeter for 12v
2) Check alternator with a multimeter for 13-14v with engine running
Old Oct 15, 2013 | 10:21 PM
Is it possible that a really worn out key with very rounded, worn down edges will affect recognition of the key and make theft deterrent fuel enable signal lost occur.
milrlyt
Oct 11, 2012 06:21 AM
skylark65
Sep 10, 2011 12:54 AM
04intimidatorssjmm
Aug 24, 2010 09:09 PM
jsteezy129
Nov 15, 2005 10:47 PM
