PCM Swap ---> Please Help!
Old Jan 16, 2013 | 08:40 PM
Jparks's Avatar
Default PCM Swap ---> Please Help!
So I've decided to do a PCM swap in my 06 Monte SS to pass my E-test.
My mom is loosing her mind because she wants to do it before I go home.
My questions are:
How easy is it to remove the PCM currently loaded?
Do you have any step by step or diagrams?
Removing it, is the whole thing the "core" as I want to save money and just send it to overkill in Toronto.
Old Jan 16, 2013 | 09:43 PM
Jparks's Avatar
Found a good step by step does this look right?
http://www.crownvic.net/tech/chip_install.html[/COLOR]
Old Jan 16, 2013 | 10:42 PM
Jomao_o's Avatar
I recommend you just get a cat welded on, that is, if you already have the CAT.
The pcm was held in place by 'clips' on my 04 before I added the cai.
Old Jan 16, 2013 | 10:59 PM
Jparks's Avatar
I'm doing the cat but if it throws a code Im going to need the PCM
Old Jan 16, 2013 | 11:03 PM
Jomao_o's Avatar
Oh Ok, I see.
You want it tuned out. It is not hard to remove at all.
Pure2sin
May 26, 2025 04:56 PM
Henderson21
Jul 26, 2014 03:37 PM
puffins629
Jun 1, 2011 11:15 AM
The_Maniac
Nov 10, 2010 09:42 AM
MonteSS2001
Jul 18, 2007 10:22 PM
