Pass side window will not go up with new switch, only down.
Old Oct 5, 2006 | 09:51 PM
montecarloenthusiast's Avatar
Default Pass side window will not go up with new switch, only down.
My passenger window will not go up when I push the passenger side switch up, it only will work when I push it down. The window will move both ways using the driver side switch. I thought I needed a new switch, but the new one still didn't solve the problem. I put a test light onto the harness that plugs into the window lift motor. It lights up on the one contact if I push up and it lights up when I push down on the other contact, so I am getting voltage to the motor from the passenger side switch. It doesn't make sense. I even replaced the motor, which is what I thought was the original problem. If I am getting voltage to the motor, why wont it work in the down position/only up position, but will work both ways from the driver side?
Does any one have any ideas?
I would greatly appreciate the help!!
Old Oct 6, 2006 | 12:13 AM
Bigg J's Avatar
Default RE: Pass side window will not go up with new switch, only down.
Hmmm, that is a truly esoteric situation. I would just have the shop check it out. Sounds like you have done all you can do, no?
Old Jul 10, 2007 | 06:20 PM
trbochrg's Avatar
I have the same problem, anyone have any ideas?
stumped
Feb 20, 2015 07:45 AM
Jester_20
Aug 24, 2014 02:29 PM
crev64
Jun 27, 2011 08:50 PM
Suppoko
Aug 26, 2009 06:48 PM
z34phoenix
Feb 18, 2007 03:23 AM
