6th Gen ('00-'05): Oil pressure switch help
Old Sep 13, 2025 | 06:57 PM
Slick28's Avatar
Default Oil pressure switch help
Need some help and ideas. My 2002 with 3.8 had a leak at the oil pressure switch. I replaced it. All good then about 3 months later it blew oil out of it like a stream and lost alot of oil. Changed the oil and replaced the pressure switch. A couple months later boom started to blow oil out through the switch again. Changed it again today and within 1 hr blowing oil through it again. I thought the oile pressure was to high for some reason so I hooked up and oil pressure guage. Cold start 70 psi after warming up it drops to around 40-45 psi. The car has around 120k miles . Any ideas?
Old Mar 12, 2026 | 07:49 AM
02MonteSS_D.E.'s Avatar
The only thing I could think it would be a is the oil pressure relief valve in the engine sticking. Have you tried a new oil filter at any point after replacing the sensors. I have opened these sensors up before and there is just a thin piece of plastic that is a diaphragm that pushes against a copper disk to break a connection when I believe it's 7 psi and higher. So I could see extreme pressures blowing this diaphragm out. Even though the gauge moves on the dash it just a dummy pressure indicator. The engine calculates this with engine temp and rpm.
gtr25
Nov 28, 2021 02:45 PM
Metroboomin
Oct 13, 2017 11:11 PM
JEMLT1
Aug 6, 2013 09:35 PM
Randy Biron
Jul 14, 2012 08:07 PM
RoyAAdams
Nov 17, 2011 11:42 AM
