oil filter
Old Nov 1, 2012 | 11:56 AM
I'm curious and I'm willing to be enlightened... What is the reason behind going to a longer filter. Obviously it will hold more volume of oil, but what make it attractive to do??
Old Nov 1, 2012 | 04:30 PM
aussiek2000's Avatar
Holds more oil, holds more dirt, better heat dissipation, easier to get on and off, same price. What is not to like? And GM Ultraguard filters only come in 52 size. so....
Old Nov 2, 2012 | 10:33 PM
boggie's Avatar
thanks again for the info
Old Nov 3, 2012 | 12:43 PM
HammerV8's Avatar
I'm partial to wix/napa filters and K&N. They always rank high on the filter tests. the K&N has the nut on the bottom for ease of removal with headers in the way. On small block chevys, I like to use a big block filter for extra oil capacity.
Using a bigger filter for extended changes is incorrect. I would also recommend changing it at every oil change. As cheap and ease of removal they are, its not worth the risk. And who wants clean oil running through a dirty filter
I'd stay away from fram. I've heard horror stories of blowing up fram filters while driving, locking up motors
Old Nov 3, 2012 | 04:24 PM
monte07's Avatar
i have been using fram there pretty good on doing the job. never heared of it blowing off of a engine and causing a engine to lock up.
Old Nov 4, 2012 | 09:11 AM
MAMONTE's Avatar
I can't remember off the top of my head right now, but I THINK the 06/07 V6 Monte's come stock with the PF 52 Ac Delco...I know it's a larger filter than the 3800's stock filter.
For anyone looking to extend the drain interval, a filter alone is not the way to do it. If you put a quality oil filter AND fully synthetic oil, you can safely extend your drain interval.
shmedley
15
Oct 10, 2008 06:54 PM
RickCoMatic
Jan 3, 2008 02:08 PM
BeachBumMike
Aug 8, 2007 07:22 AM
saluteTOme
Jul 3, 2007 11:40 AM
Crimsonslayer
Jan 28, 2005 11:39 PM
