need help
Old Oct 30, 2012 | 08:41 AM
manny04monte's Avatar
Default need help
how you guys doing im new to the site an i need help with my 04 montecarlo ls and i hear water or something in my dash an sometimes after it rains it leaks through the passenger side floor and also i notice the anti-freez is low more than it should but i see no leaks on motor or on the floor any clue to what could it be thanks
Old Oct 30, 2012 | 05:43 PM
nobody knows i tried looking myself but no luck thanks anyways
Old Oct 30, 2012 | 06:43 PM
03SSLE's Avatar
Greetings!
We have memberrs coming and going 24/7 but sometimes it may require a little patience for a question to receive a reply. It sounds like the cowl seal for the cabin air filter is leaking. This is a common problem with the W body cars. There's a 'sticky' about this problem located in the How-To Section/6th Generation Monte Carlos:
https://montecarloforum.com/forum/si...lem-fix-26663/
Good luck - Hope you get it fixed.
Edit: Somehow I missed the anti-freeze part of your post. It sounds more like a leaky heater core. When it rains you probably use the heater more and that's why you notice an increase in the leak.
Old Oct 30, 2012 | 06:44 PM
boggie's Avatar
check the oil could be head gasket could be leaking thru the fresh air filter also check radiator. could be leaking on to a hot exhaust pipe these are just a guess
Old Oct 30, 2012 | 09:54 PM
YelloJac's Avatar
From: Garfield, New Jersey. But my Home will always be The Bronx
Do you notice a mist on the windshield either with your heater on or off? This will be caused by your heater core leaking. You will also have a sweet smell like antifreeze in the car and your coolant will get low. Other than that, a leak in the engine compartment will not go thru your firewall. A leak in the windshield could cause it too but I would think you would see other signs of that. I don't have any experience with Fresh Air Filters but I'm sure others here do. Good luck!
Old Nov 3, 2012 | 08:07 PM
thanks ill look into it more just back from ny and my waterpump went so now i got to fix that
Old Nov 4, 2012 | 11:26 AM
could my water pump have went because mixed antifreeze i had dexcol and on a last min buy i mixed it with peaklife i didnt think it would be a problem but some ppl are telling me its not good
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
zk6216
Mar 11, 2008 11:19 PM
mickey
Aug 23, 2006 05:31 PM
