Obnoxious squeak every time I reverse! Help
Old Apr 15, 2014 | 11:31 AM
JFMonteCarlo03's Avatar
Default Obnoxious squeak every time I reverse! Help
Everytime I back out of my driveway I get this what can sometimes be very loud and obnoxious screeching noise, to the point where you want to cover your ears. Sometimes it's just a little squeal, I was wondering what the problem could be, it sounds like it's coming from both front tires. The break pads on them were just changed recently so that might have something to do with it. Just bought the car
Old Apr 15, 2014 | 12:03 PM
Welcome to the forum...
Have you had the front end checked on the vehicle?
Could be dry CV joints on the axles...
Maybe when the person did the brakes..they weren't done correctly and the wear squeakers are to close to the rotor? Maybe the backing plate is also rubbing the rotor? something to consider...
I'm sue someone else will chime in with more suggestions/ideas!
Once you do figure it out..please let us know so we can pass this info on to others that maybe experiencing the same thing.
Thanks for joining the MCF Family!
Old Apr 15, 2014 | 12:07 PM
Just off the top of my mind, I would have the pads/rotors inspected. Something may be bound that the noise only surfaces in reverse. Check for even pad wear and also ensure that each brake has a pad with a warning tab (and that pad should be on the outside face of the wheel, not the pad the piston is pushing). I have seen where a guy at a shop put both pads with warning tabs on one wheel and then pads without tabs on the other wheel.
But that is where I would first suspect without actually hearing the noise myself.
Old Apr 16, 2014 | 08:38 AM
Thanks for all the info guys. This is an awesome forum site and I'll be keeping updated. I've took off the 2 front wheels and visually inspected the assembly. Nothing seemed out of place or loose. But now during reverse when I turn it turns my traction light on and makes a knocking noise, or it will sometimes do that at hard turns. Gonna take it to the shop in a couple days and take apart the brakes and check everything you guys have said
Old Apr 16, 2014 | 11:17 AM
JC Colon's Avatar
It's not likely but I would check out the hub assembly as Well. Along with the brakes and CBS Axle. But more than likely It's the brakes.
I only suggest the hub assembly because you are getting the squeak and your Traction light around hard turns. The Traction and ABS are associated with the hub bearings. Otherwise I would say It's definitely a brake problem.
Old Apr 16, 2014 | 11:37 AM
JC Colon's Avatar
Old Apr 16, 2014 | 11:44 AM
I agree with JC, since the trac light came on, inspecting the wheel hub would be advised. Just check the entire suspension for anything loose or with play in it or broken.
Old Dec 28, 2014 | 02:39 PM
Tonya Femmejolie Reyes's Avatar
Thank you!!!
Habbibie
Apr 26, 2015 02:32 PM
AwesomeSS
MCF Website Problems & Issues
34
Aug 14, 2014 08:21 AM
thtGuy
May 7, 2013 08:28 AM
Enzo354
Jul 23, 2012 06:43 PM
zapp59
Aug 5, 2007 11:44 AM
