OBDII not communicating to the ECM/PCM
Old Jan 18, 2014 | 10:54 PM
matt99199's Avatar
Default OBDII not communicating to the ECM/PCM
So i rooted around underneath my 2000 SS monte carlo and my airbag light is now constantly on. I tried using a scan tool to test if it could read srs codes but when i tried any code scanner it could not connect to the ECM/PCM. So, i checked all wires to make sure nothing was disconnected. Nothing appears to be out of place. I checked for voltage on the OBDII connector and it was good at 12.4V. I checked connection on the serial data wire between the ECM and the BCM and that was good.
My question is, where does the purple wire on the OBDII connector turn into the green wire connected to both the ECM and the BCM. I would like to test connection on this wire, but I just cant find where the purple wire from the OBDII goes...
Any help?
Old Jan 18, 2014 | 11:07 PM
djhixter's Avatar
Check the cigarette lighter fuse...if this fuse is blown, you wont be able to communicate with the pcm
Old Jan 18, 2014 | 11:17 PM
l67ss's Avatar
Can tell you how to turn off the lite permanantly, but you wont have airbags
Old Jan 18, 2014 | 11:21 PM
djhixter's Avatar
Any help?
I think from his post he cant get into the actual pcm
Old Jan 18, 2014 | 11:46 PM
l67ss's Avatar
Myway doesnt involve the pcm
Old Jan 19, 2014 | 08:42 AM
03SSLE's Avatar
RDUB8
Nov 7, 2011 12:31 PM
Tdogg527
Feb 11, 2010 07:44 AM
xman23
Jul 13, 2008 04:41 PM
bowtietech
Feb 27, 2008 09:26 AM
Peer81
Mar 8, 2007 06:29 AM
