Pcm/ecm
Old Nov 7, 2011 | 07:56 AM
RDUB8's Avatar
Default Pcm/ecm
I have a 2004 Monte 3.4 engine. I just had the transmission replaced. Ever since then I have been having an electrical issue. While driving all of my gauges shut down and the car makes this scrapping sound. I don't lose any power and the gauges go right back to normal. Is this an indication of the PCM or the ECM going out. If its the PCM could the transmission shop have put the wrong transmission in the car?
Old Nov 7, 2011 | 12:31 PM
nitehawkjcb's Avatar
Sounds more like a BCM issue (body control module)
But it could be the PCM failing
If it was the wrong transmission, your car would shift HORRIBLY.
Check all your grounds.
Tdogg527
Feb 11, 2010 07:44 AM
xman23
Jul 13, 2008 04:41 PM
bowtietech
Feb 27, 2008 09:26 AM
Peer81
Mar 8, 2007 06:29 AM
