OBDII Code P0453
Old Dec 12, 2008 | 02:09 PM
2slow4u's Avatar
Default OBDII Code P0453
My 01 LS is throwing the listed code, which has to do with the Evap. Emission System. From my searching I've found that it may be the "fuel tank pressure sensor" is faulty since the code definition is "input voltage is higher than the maximum". I've fiddled with the gas cap as a possible cause, too. Does anyone know where this "fuel tank pressure sensor" is? I've read some cars have them under the hood and some have them on top of the gas tank.
Old Dec 13, 2008 | 04:49 AM
bowtietech's Avatar
Default RE: OBDII Code P0453
The fuel tank pressure sensor is located on top of the fuel pump/fuel level sensor module. In the trunk there is a fuel pump access panel located under the carpet.Remove the carpet and the access panel and its easy to replace the sensor.Just unplug the 3 wire connector from the sensor and pull it out of the module.
LennyLeonard
Nov 15, 2016 06:02 PM
matt99199
Jan 19, 2014 08:42 AM
One Dark SS
Dec 1, 2009 10:00 PM
AUTOXR
Apr 23, 2008 03:34 PM
king2805
Jul 14, 2005 10:34 AM
