OBDII code 0171
Old Apr 22, 2008 | 10:31 AM
AUTOXR's Avatar
Default OBDII code 0171
I have a 2001 Monte 3.4 200,000 miles. Yes I said 200,000 miles. Recent repairs, new Catylitic converter, new MAF sensor, rebuilt tranny. It now shows a P0171 code. Any guesses?
Old Apr 22, 2008 | 11:03 AM
Nocturnx's Avatar
Default RE: OBDII code 0171
I found this:
http://www.obd-codes.com/p0171
A problem with the new MAF sensor maybe.
Old Apr 22, 2008 | 07:20 PM
RocknSS04's Avatar
Check the connection on the MAF, also the PCM.
Old Apr 23, 2008 | 03:34 PM
AUTOXR's Avatar
Thanks for the suggestions. The fix (I hope) turned out to be fairly simple. Some Rodent (a red squirrel?) tried making a nest in the air filter box shredding a 3" x 6"section in the air filter. The paper was sucked through the wire supporting mesh of the filter and jammed in the MAF screen. Cleaned the MAF, Airfilter box and replaced the filter. Cleared the code andI am waiting to see if that takes care of it. Glad I checked it prior to taking it into the shop. Now I have to get me a squirrel or some free flowing wire mesh (Hardware Cloth) to fit the intake opening. Thanks again for the suggestions.
LennyLeonard
Nov 15, 2016 06:02 PM
matt99199
Jan 19, 2014 08:42 AM
One Dark SS
Dec 1, 2009 10:00 PM
2slow4u
Dec 13, 2008 04:49 AM
king2805
Jul 14, 2005 10:34 AM
