no sound when I turn key
Old Feb 13, 2014 | 11:55 PM
HoustonChevyBoyz's Avatar
Default no sound when I turn key
All the lights on dash blinking car wont start no sound when I turn key......went back 1hour later no lights an no power got a jump and got power but still no sound when I turn key
Old Feb 14, 2014 | 07:59 AM
owens91's Avatar
If there was no humming could be a fuel issue. If u heard that then depending on ya location the starter could be frozen over or defective. Make sure u check all fuses before u buy parts tho
Old Feb 14, 2014 | 10:22 AM
It has over a half tank of gas there is no alarm but every blue moon when I turn it off and walk away I here it beep twice like and alarm and a few days ago it wouldnt start it said theft detterent so sat there and tried it again it worked but last night it lost all power and doesnt make a sound when I turn key so I can get power for the lights the horn and locks but its completly quiet when i turn key
Old Feb 15, 2014 | 11:00 AM
owens91's Avatar
Deff sounds like there's a problem with the security system there is a way to reset it you should sesrch some where on the forum
Old Feb 15, 2014 | 02:03 PM
JC Colon's Avatar
Does "Security" flash at you when you when you turn the key to the "On" Position? If So you are in Security Lockout. Your "Passlock" system has activated and you need to do the Security or Pass-Lock Relearn!
Old Feb 16, 2014 | 06:28 AM
03SSLE's Avatar
Charge your battery then check it to make sure it is healthy. Check your battery cables. You can have enough amperage to power the lights, horn, etc but not enough to turn the starter motor. If the car won't start with a fresh battery and tight, clean battery connections then do a security relearn.
Old Feb 17, 2014 | 06:25 AM
Yea fresh battery hooked it up to the computer and ut want even read nothing theft detterent locked me out had to have it towed to a shop tried 30 min re learn couldnt do it
Old Feb 17, 2014 | 08:01 AM
owens91's Avatar
aww that sucks, i hope u are able to get ya ride back on the road soon
Old Feb 17, 2014 | 09:18 AM
03SSLE's Avatar
Have you checked all the fuses for the PCM and starter circuit?
Old Feb 18, 2014 | 06:07 PM
Turns out computer is fried falty wiring getting in rewired and replacing chip in the computer will have update soon
MonteCarloKZ
May 6, 2024 10:26 AM
jeff2425
Jul 26, 2008 07:29 PM
victoryred05
Jun 18, 2008 09:17 AM
ww
Mar 17, 2007 01:50 PM
fedspunisher
Dec 19, 2006 04:25 PM
