Monte Carlo SS hesitating
Old Feb 18, 2014 | 10:20 AM
Kobbe's Avatar
Default Monte Carlo SS hesitating
Hi,
I have a 2002 Monte Carlo SS with 70,000 miles, its starting to hesitate when I start from a stop and it shifts through the gears, could it be the plugs or wires ?
changed the inline fuel filter about 1000 miles ago.
Thanks
Kobbe
Old Feb 18, 2014 | 10:33 AM
owens91's Avatar
Originally Posted by Kobbe
Hi,
Thanks
Kobbe
hey there and welcome to the forum, that is a pretty low milage monte you got there. if u just got it, me personally i would change the spark plugs and wires out asap cause you may never know what you would find
Old Feb 18, 2014 | 10:43 AM
Kobbe's Avatar
Thanks
Bought it new sept. 2001 wife's car, works a mile from home. do you think the wires and plugs are the problem.
Thanks
Kobbe
Old Feb 18, 2014 | 11:46 AM
dbaldwin's Avatar
A plugged cat is also a common problem. Does it feel bogged down and like its having trouble shift in out of first? I believe the 2000-2001 had a batch of bad cats in the mix from the factory. Check underneath after a long drive to see if the cat is glowing red, this indicates a failure.
Old Feb 18, 2014 | 12:07 PM
FYI - Moved thread to Monte Carlo Repair Help.
Old Feb 18, 2014 | 02:10 PM
JC Colon's Avatar
to MCF
Swapping your plugs is a good idea. I would also clean the MAS and TPS. Maybe put in a bottle or 2 of Fuel Injector Cleaner!!!!!
Old Feb 18, 2014 | 08:44 PM
DaNfRoMSt.PaUl's Avatar
Plugs and wires are a good place to start.
03vaderSS
Aug 23, 2014 05:51 PM
Chefjared
Mar 21, 2012 10:15 AM
Dovas Monte
Feb 1, 2011 01:24 PM
team monte carlo ss
Aug 11, 2008 06:02 PM
