No power and not wanting to rev.
Old Aug 17, 2011 | 07:38 PM
silver86's Avatar
Default No power and not wanting to rev.
My monte carlo sat for about 7 months. I finally got it running and then had to replace the crank sensor. Now it doesnt make any power and I cant drive it because it has a hard time moving. It doesnt have a miss and actually runs smooth with no check engine light or anything. It reminds me of when the cat. went out but I have eliminated the exhaust as the culprit. Any help on what to check would help a lot right now.
Thanks
Old Aug 17, 2011 | 09:27 PM
Wilco's Avatar
IDK if you've tried this but you may want to do a relearn procedure, for starters, then go from there.
Old Aug 18, 2011 | 08:07 AM
How long has it been running?
Did you ever get fresh fuel in? What about all the other fluids??
Old Aug 18, 2011 | 10:23 AM
What all has been done to it? Fuel filter, spark plugs, Air filter?
Old Aug 18, 2011 | 08:53 PM
silver86's Avatar
Can you please lead me the procedure for the relearn?
I did get fresh fluids in it. It was down because of a lifter that collapsed. So I replaced the oil and coolant when I replaced it. I also put fresh fuel in it. After I fixed that it was running fine. The next day it wouldnt start so I replaced the crank sensor and it fired right up. But now it doesnt have any power to it.
The fuel filter was replaced just before it sat. Plugs and air filter are new.
sdowney
Apr 6, 2013 08:57 PM
billyjblunt79
Dec 5, 2012 02:10 PM
undeadmetalshred
13
Apr 4, 2012 01:42 PM
Buddy K
Dec 1, 2011 11:12 AM
3800ss04
Feb 19, 2008 03:20 PM
