No lights! HELP!:(
Old Oct 5, 2010 | 11:45 PM
Pure2sin's Avatar
Default No lights! HELP!:(
I was playing with moduels for my radio and somehow ended up shorting out my dash, HVAC and lock/unlock window lights (I AM AND IDIOT!) I am doing my top swap in 2 weeks need to figure this out. I already replaced the dimmer switch/Headlight switch. Could it be the other dimmer switch that is the turn signal lever? What are the Relays and fusees that are connected to this system? Everything else lights up fine but the DRLS are also out. Its very weird because when I turn the car to on no lights come on but the odometer and then that dims out to where you can barley see it.
Old Oct 6, 2010 | 01:12 PM
Pure2sin's Avatar
I figured it out. Apparently the tail light fuse blew causing the other lights to go out.
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
RickAKATed10
Jan 23, 2009 10:38 AM
espo83
Sep 12, 2008 10:00 PM
Zackb911
Dec 22, 2006 07:22 PM
