Proper Amount of Transmission Fluid
Old Oct 6, 2010 | 05:51 PM
LynnKeefe's Avatar
Default Proper Amount of Transmission Fluid
My 1996 Monte Carlo Z34 has been sitting for a year...and partly due to my own improper maintenance of the year prior and partly due to the prior owners, my transmission fluid is as low as it can get.
However, I can't find my owner's manual or any of my automotive guides to know how much transmission fluid it can handle, so I get the right amount in there...and don't spend more than I have to.
Any help is greatly appreciated.
Old Oct 6, 2010 | 05:59 PM
The Popcorn King's Avatar
First thing you have to do is pull the dip stick and see if it even has any oil on the stick. If is DOESNT, then you are at least 2 quarts low. Anything after that is a guess. What i would do is get about 4 qts and put it in one at a time. Check your dip stick to see if its starting to shows. You can always return what you didnt open.
Dec 14, 2014 06:43 AM
dustybird3
Dec 1, 2009 09:32 AM
jay26
Jul 12, 2008 12:09 PM
BeachBumMike
Jul 15, 2007 09:42 AM
Autogeek
Nov 11, 2006 01:53 PM
