6th Gen ('00-'05): NO Hazards NO Brake lights
Old 07-18-2014, 10:52 AM
DEI3FAN8's Avatar
Default NO Hazards NO Brake lights
Hello all!
I have a 2000 Monte Carlo SS. I'm having issues with the Brake lights and hazards. My blinkers are working and the Tail lights come on but no hazards or brake lights. We have tested the power to the rear lights, it was not getting power. Tested the fuse box where the Hazard switch fuse is and there was no power. Next we opened up the dash and tried to replace the hazard switch with no change. Any Ideas of what might be going on? Im also not getting power to my blower for the AC and Heat. It used to work on setting #5 but now nothing. Thank You for your time.
DEI3FAN8
Old 07-18-2014, 03:22 PM
replace hazard switch in dash
for blower issues, replace blower motor resistor under the dash
Old 07-18-2014, 03:43 PM
DEI3FAN8's Avatar
We tried a replacement switch already but it had the same issue. Turning Signals work but the hazards wont come on or the Brake lights. Fuse looks good but no power when tested at the box.
Old 07-20-2014, 09:28 PM
DEI3FAN8's Avatar
I'm testing the brake light switch now, Getting power to all four wires in the first connector but the connector with the orange and white wire im not getting anything on the tester?
Old 08-11-2014, 10:32 PM
DEI3FAN8's Avatar
Replaced Brake Switch but still having the same problem. When testing the fuses on the passenger side. Im not getting power to the Brake Switch, Hazard switch, HVAC Blower, AUX, and CIG. Blinkers are working and so are Taillights, We tried replacing the Flasher also but that wasnt it. Any other suggestions?
Old 08-12-2014, 05:28 AM
Wiring manual shows that all of those items are run though individual fuses in the passenger side fuse block, but they all are powered from a single 60 amp fuse labeled RT I/P in the top underhood fuse block. Check there.
rg9johns
08-22-2014 10:46 PM
hotrodharley
10-11-2013 07:13 AM
Sparky-88
04-07-2012 07:39 AM
Zackb911
12-22-2006 07:22 PM
Quick Reply: 6th Gen ('00-'05): NO Hazards NO Brake lights
